Droid x charging
This is a discussion on Droid x charging within the Droid X Accessories forums, part of the Droid X Extras category; I purchased the package from verizon with the jabra vbt3050 headset. My ? Is can i use the charger that came with the headset to ...
Like Tree2Likes
  • 1 Post By e3zkiel
  • 1 Post By smalltowngirl13
Thread: Droid x charging
    Question Droid x charging
    I purchased the package from verizon with the jabra vbt3050 headset. My ? Is can i use the charger that came with the headset to safely charge my droid x?
    Points: 2,861, Level: 32
    e3zkiel's Avatar
    6303
    California
    216
    11 times
    Check to see if the current rating on the charger does not exceed the rating of the manufacturer's. I believe that the original charger is 850 mA. If it's lower than that it will take longer to charge your X but is also safe to use. If it's too low it won't even charge the X. Good luck!
    Acls likes this.
    Nokia handheld -> LG flip phone -> Storm -> Droid X
    ROOTED and lovin' it
    running Android
    4.0.4 - currently using Gummy 1.2.0 - 5/9/12 [BETA]
    Points: 70,925, Level: 100
    Overall activity: 29.9%
    20,493
    876 times
    Quote Originally Posted by e3zkiel View Post
    +1 Exactly what he said
    Acls likes this.
    Guidelines of Conduct for DroidXForums.com
  1. Charging the Droid X battery
    By Exit14 in forum Droid X FAQs
    Last Post: 09-10-2010, 06:21 AM
  2. car charging the dx
    By kieran in forum Droid X Help
    Last Post: 08-29-2010, 05:03 PM
  3. problems while charging...
    By under003 in forum Droid X Help
    Last Post: 07-25-2010, 01:50 AM
  4. LED Charging Issue??
    By DroidXfactor in forum Droid X General Discussion
    Last Post: 07-20-2010, 10:42 PM
  5. DROID X - Charging
    Last Post: 07-15-2010, 01:03 AM
amps it takes to charge droid x
best cm4dx theme
charge current droid x
charging droid x
current charging droid x ma
droid x charge current
droid x charge time
droid x charger current
droid x charging current
droid x current for charging
droid x says its charging but its not
droid+x+charging amperage
how to charge a droid x
how to charge droid x
jabra charger to charge my droid x
