Little help on Blue Tooth Headphones
This is a discussion on Little help on Blue Tooth Headphones within the Droid X Accessories forums, part of the Droid X Extras category; Jabra clipper. Use and headphones and turn them into bt wireless headset. Built in mic allows you to take calls. The music pauses when a ...
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
Thread: Little help on Blue Tooth Headphones
    Jabra clipper. Use and headphones and turn them into bt wireless headset. Built in mic allows you to take calls. The music pauses when a call comes in.
    Points: 925, Level: 16
    Level completed: 25%, Points required for next Level: 75
    Overall activity: 0.0%
    ryay87's Avatar
    14644
    I have had the 903 Backbeats and did not like the sound as compared to the Motorola S9-HD's. The Motorola ones sound awesome. I am getting the S10-HD's that come out 10-24-10. Get them you will love them.
    Drachnem's Avatar
    2915
    35
    I just bought the Moto H17txt and it is amazing. Awesome volume, plays music, reads text messages and emails, tells you who's calling, super small. Check it out. I'm in love.
    Points: 39,537, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,091
    243 times
    I can't be much help I have the Motorola H17txt and absolutely love it
    Points: 1,780, Level: 24
    Level completed: 80%, Points required for next Level: 20
    prpredators's Avatar
    16471
    48
    I have the Moto Rockr (i think they are S9). For some reason I can use it for phone, but it doesn't seem to play music. is there a setting that I need to change? I figure once I pair it, all functions should work.
    Points: 756, Level: 14
    Level completed: 56%, Points required for next Level: 44
    Droid_Junky's Avatar
    16506
    I bought the Rocketfish Headphones from Best Buy and I love them. Rocketfish™ Mobile - RF-MAB2 High-Definition Stereo Bluetooth Headphones - Black - RF-MAB2
    I listen to Slacker while working in the yard and if a call comes through i can just answer the phone. Music controls only work with the default music player though. It actually has preset EQ options that makes them sound even better.
  8. #17
    garnold's Avatar
    8070
    15
    I'm hoping to get the SD10-HD when I can get to BestBuy. I have heard good things about the back beats and they are on my short list if the SD10's don't pan out.
  9. #18
    Points: 4,890, Level: 44
    Level completed: 70%, Points required for next Level: 60
    Overall activity: 1.4%
    Intimdtr77's Avatar
    17057
    555
    Quote Originally Posted by psychotic_penguin View Post
    Quote Originally Posted by ryay87 View Post
    Regarding these two, will they work with any player such as Double Twist? Someone commented their phones only work with the default player on the DX.
  10. #19
    16471
    48
    Quote Originally Posted by prpredators View Post
    I was able to get these to work and listen to all music on my headset. I had to reset my entire phone, which kinda sucked because I lost the settings taht I already had but I'm glad it works now
  11. #20
    garnold's Avatar
    8070
    15
    How are the back beats working for you? I found a pretty good deal for them on the web ($37) so I bought them rather then the SD10. Should be in this week.
  1. Blue tooth earphone for DroidX
    By Swiss in forum Droid X Accessories
    Last Post: 01-15-2011, 07:35 PM
  2. Can I hook a blue tooth keyboard to the phone?
    By ludasco in forum Droid X General Discussion
    Last Post: 08-17-2010, 09:29 PM
  3. Notifications through headphones
    By Mindcloud in forum Droid X Audio / Video
    Last Post: 08-11-2010, 02:47 PM
  4. Blue Tooth reviews?
    By Phatkat66 in forum Droid X General Discussion
    Last Post: 07-25-2010, 12:03 AM
  5. Blue tooth voice dailing and NOFX
    By jmartinez06 in forum Droid X General Discussion
    Last Post: 07-17-2010, 09:11 AM
motorola sd10
motorola sd10 hd
motorola sd10 pairing
motorola sd10 review
motorola sd10-hd
motorola sd10-hd manual
motorola sd10-hd pairing
motorola sd10-hd review
motorola sd10-hd reviews
motorola sd9 vs sd10
