Extended battery - how many more hours?
This is a discussion on Extended battery - how many more hours? within the Droid X Accessories forums, part of the Droid X Extras category; I got 40 hours out of my last charge. One day of light use and one day of heavy use included in that 40 hours. ...
View Poll Results: How many more hours are you getting with ext bat?
Voters
22. You may not vote on this poll
  • About the same
    4 18.18%
  • 1-2 more hours
    3 13.64%
  • 3-4 more hours
    5 22.73%
  • 5-6 more hours
    3 13.64%
  • 7+
    7 31.82%
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Extended battery - how many more hours?
  1. #21
    1000 Experience Points500 Experience Points250 Experience Points100 Experience Points7 days registered
    shinjaejun's Avatar
    2584
    Pennsylvania
    278
    I got 40 hours out of my last charge. One day of light use and one day of heavy use included in that 40 hours. It was awesome.
    Sent from my DROIDX
    I'm not angry, I'm from Philly
  3. #22
    Points: 3,860, Level: 39
    Level completed: 40%, Points required for next Level: 90
    anomaly's Avatar
    573
    151
    its hard to say how many hours more i get. (i voted 7+) but id say it more like 30% more life.
    some days a barely use my phone at all and it would seem it could last about 3 days at that rate. other days i stream Pandora and surf the web for a few hours and id assume id get about a 24hrs worth. some days i use the crap out of this thing and it might just last 16-18 hours.
    but the thing i like most is that it didn't make the phone huge and now i don't worry about battery life... and this is with out optimizing (turning stuff off, dimming the display, etc).
    before with the stock battery i barley made it thru 16 hours when i actually used the phone for stuff other than text and that was with some sacrifices like low brightness, GPS off, Syncing less often, etc.
    if anyone is having any doubts about this thing id just do some simple math.
    take the number of hrs you get with your current battery and divide that by 15 (15 = 1500mAh) then multiply that number by 19 (19 = 1900mAh) and that should give you a good idea of what to expect for the extra cash your are thinking of dishing out for this extended battery.
    oh and just to add a tip: i seem to get a much better charge when i charge up with the USB cable vs the AC adapter. it seems to take much longer to charge up but if you have the time its worth it. i charge off my PC at work every day and it takes maybe 4-5hrs to top off the charge from 50-60%.
  4. #23
    Points: 1,386, Level: 20
    Level completed: 86%, Points required for next Level: 14
    ionorick's Avatar
    88
    43
    Jeez didn't know batteries were so complicated...i do need to get the extended battery though
  1. 30% off Extended Battery for Droid X
    By irod87 in forum Droid X Accessories
    Last Post: 04-18-2011, 11:13 PM
  2. Extended Battery + Case?
    Last Post: 04-08-2011, 08:34 PM
  3. Extended Battery! YES
    By msburr87 in forum Droid X Accessories
    Last Post: 09-03-2010, 03:48 PM
  4. Up to 50% off Extended Verizon Battery?
    By zettler in forum Droid X General Discussion
    Last Post: 08-28-2010, 09:19 AM
  5. Extended battery really 1930mAh??
    By OutGolfn in forum Droid X Accessories
    Last Post: 08-13-2010, 04:15 PM
1900mah battery equals how many hours
droid x extended battery hours
extended batteries lasts how many hrs
how long can 1900mah last?
how many hour to charging extended battery
how many hours does the droid x have
how many hours does the droid x last
how many hours does the extended battery last
how many hours will 1900amh battery last
mow many hours of charge is 1500mah
