Is there a pouch with a magnetic closure that does not activate the Car Dock app?
This is a discussion on Magnetic closure questions within the Droid X Accessories forums, part of the Droid X Extras category; Is there a pouch with a magnetic closure that does not activate the Car Dock app? Sent from my DROIDX using Droid X Forums...
No, the dock is activated by a magnet, so any holster with a magnet will trigger it.
Sent from my Android device.
How to root your phone
How to SBF an X2
How to SBF an X
Guidelines of Conduct
iPhone - You're holding it wrong
So, how do you carry yours?
Front pocket - check. Is it in a protective glove of any sort?
I thank you sir.
Does the Incipio fit with the extended battery?
i only use the stock batt. so i cant answer that, its seems it may but would be tight
