Using gps charger for droid x
This is a discussion on Using gps charger for droid x within the Droid X Accessories forums, part of the Droid X Extras category; Installed a mount for my droid x on my hayabusa. Have a gps car charger installed on the bike bc i normally have my gps ...
Results 1 to 10 of 17
Thread: Using gps charger for droid x
    Points: 3,032, Level: 33
    Level completed: 88%, Points required for next Level: 18
    Overall activity: 4.6%
    hemi1300's Avatar
    19933
    111
    Installed a mount for my droid x on my hayabusa. Have a gps car charger installed on the bike bc i normally have my gps on it. I ordered a mini usb to micro usb cable so i can use the same charger to charge my droid x on the bike. Will the charger work fine without causing damage to the x? Should be the same voltage, but figured i would check before i try it so i don't damage my phone if it won't work
    Moderator
    Points: 25,450, Level: 96
    Frequent Poster
    mikeinrichmond's Avatar
    9010
    Richmond, Va
    7,668
    392 times
    Yes, as long as the voltages are stepped down then it should be fine. The bigger problem is with the vibration of the bike, esp. if you are mounting it in the bars. Many phones and GPS's made for cars, have suddenly died this way, since they are not built with this purpose in mind. Personally, I leave my phone in my pocket or tankbag wired into my helmet for music/phone etc, and use my Garmin 2610 for Nav. since it was made to take the vibs...
    Points: 6,192, Level: 51
    Overall activity: 0.7%
    spodoc's Avatar
    17924
    2,040
    88 times
    Mike what would be a max voltage? I don't see any info on my OEM charger
    Points: 9,280, Level: 64
    ryant35's Avatar
    7730
    SoCal
    1,706
    57 times
    5VDC, just about all USB chargers have the same voltage.
    Liberty 3 -- too many roms too little time.
    Points: 2,791, Level: 32
    Level completed: 28%, Points required for next Level: 109
    Overall activity: 1.0%
    h8isgr8's Avatar
    19551
    206
    11 times
    If the GPS power adapter doesn't have the USB +/- DATA pins tied together, the DX won't go into charge mode. So if you try it and it doesn't work, that's why.
    Points: 4,051, Level: 40
    Level completed: 51%, Points required for next Level: 99
    Overall activity: 10.5%
    sweller's Avatar
    26038
    310
    Quote Originally Posted by h8isgr8 View Post
    I just dissected a Moto car charger that died prematurely. It has only two wires - red and black. Thus it shouldn't matter if the USB signal pins are tied together because they don't go to the phone anyway. I believe that only applies to Moto AC chargers. Else, the PC's USB port wouldn't charge the phone. From Wikipedia, "A maximum of 5 unit loads (500 mA) can be drawn from a port in USB 2.0, which was raised to 6 (900 mA) in USB 3.0." Most folks are still on 2.0 which is why the phone charges more slowly that with the AC adapter. Faster with the Moto drivers, but still more slowly than on AC.
    You can try the GPS charger. It may or may not work. The DX has an earned reputation for being very picky about chargers in general. I've tried a multitude (both AC and DC) with very mixed results. Other than genuine Moto branded chargers, the only one that's worked for DC is an IGO charger and required adapter plug ($$) that we got at Rat Shack for my wife's Fascinate.
    The Moto AC adapter that came with my DX is rated at 5.1V @ 850mA. It's hard for me to believe that 100 millivolts is enough of a difference to prevent other chargers from working. But anything is possible.
    Final thought: Automotive (and motorcycle) electrical systems are notoriously filthy/nasty/dirty - from an electrical noise perspective, so proceed with caution. If it were my phone, I wouldn't.
    Points: 2,833, Level: 32
    Level completed: 56%, Points required for next Level: 67
    fsand's Avatar
    29998
    238
    Do yourself a big favor, don't waste your time playing around with any other charger other than the Motorola Genuine charger if you intend to use the Droid X for GPS. I have tried 5 different chargers including a genuine Verizon one and none can charge the phone faster than the GPS can drain it besides the Genuine Motorola one. Everyone says things like all chargers are the same, etc., they all have the same voltage, etc., it isn't true. The genuine moto unit charges the phone way way faster than any of the others.
    sweller's Avatar
    26038
    310
    Quote Originally Posted by fsand View Post
    HA! Next time someone says that, show them these:Guts_bot.jpgGuts_top.jpg
    The Moto charger (Top - before it died) was one sophisimacated device. A LOT of engineering went into that one. Maybe too much.
    fsand's Avatar
    29998
    238
    Quote Originally Posted by sweller View Post
    I wish I had those pictures when they did this to me. I had to use the laymans way (explained below). This all started because my GPS cradle failed. I went to the VZW store and explained my phone was no longer charging through the cradle. They gave me a new VZW charger. It still didn't charge. They then swapped my cradle. Not knowing any better at the time I kept the VZW charger and the new cradle. As the days went by I noticed my phone really wasn't charging well, it kinda seemed to be charging but it never charged up fully like it used too and some days it even seemed drained beyond when I put it in the cradle. It took me a few days to zero in on the issue but I figured out that the VZW charger was the issue. When I went back to VZW to complain I was told the chargers were the same and there was no difference etc. So I took the laymans approach to prove the point. I charged my phone at home to 100%, got in my car and plugged it up for the day with the GPS on and used it all day. With the VZW charger the phone was drained to about 30% at the end of my day. Next day I did the same thing with the Motorola charger. At the end of the day my battery was still fully charged. I then went back to the VZW store and presented them with the facts. They opened an essentials pack and replaced my charger.
    sweller's Avatar
    26038
    310
    You're not alone. Layman's terms seems to be the only way to communicate with the in-store minions (ironically).
    When I bought my first personal cell, it was in-store. It was junk and the "Service Department" fixed it three times. Frustrated, I called VZN Customer Care. They noted the account and instructed me to take it back and insist on a replacement. After a bit of "elevated" discussion (the store's rent-a-gorilla threatened to call the cops :-P), the manager produced a white-box phone. ultimately, I was banned from the store. So I called VZN Customer Care, related the whole thing to them (ironically again, the store manager's notes agreed with my story - though with slightly different embellishment), and VZN gave me three months of free service.
    The moral of my story? "The squeaky wheel gets the grease", "The customer is always right", "If at first you don't succeed ...", yadda, yadda, yadda. I believe that we (Americans) are by and large apathetic consumers. We don't do enough to demand more for our money, so we tend to take what we get.
  1. Droid X Battery Charger (not phone charger)
    Last Post: 05-09-2011, 08:45 AM
  2. droid-x charger compatibility
    By Captain Ramsey in forum Droid X General Discussion
    Last Post: 08-17-2010, 10:37 AM
  3. droid x charger vs blackberry charger
    By rubi22 in forum Droid X Help
    Last Post: 08-16-2010, 10:19 AM
  4. Droid X charger question
    By vlade in forum Droid X Accessories
    Last Post: 07-26-2010, 04:58 PM
Droid X GPS
can i use my garmin car charger for my droid 4
can i use phone charger on gps
charger for droid x
droid c charget specs
droid x charger
droid x charger specifications
droid x charger specs
droid x charger voltage
droid x chargers
