Ok, so i have seen a few discussions on here, but are all old, and hoping new information is available:
i have the BH6X, and even tho it only adds about a mm to the width, my original case and holster, while still working (very SNUG in holster), i have found that my holster is breaking. have seen that some have suggested using the case without a batter cover, but would think that even tho it doesn't get that hot, that without the cover it would get too hot in a gel or plastic cover, or would allow too much dust in to be good for phone.
would like a new case AND holster that fits the DX w/bh6x extended battery, so any help would be greatly appreciated
OK, so after reading more, i have seen examples of people saying to leave the battery case off, which sounds like it would be trouble if i used a gel cover (heat), use the old battery door cover (but that "may" cause a spot on my screen) and even "wrap a piece of plastic wrap around back and then slip cover over (??? - melted plastic on my battery and phone?)
