Ebay extended battery?
This is a discussion on Ebay extended battery? within the Droid X Accessories forums, part of the Droid X Extras category; Im seeing 1800s and 2200s and higher on ebay. These batterys come with the door as well. My questionS are 1. Are any ebay extended ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Ebay extended battery?
    Points: 3,046, Level: 33
    Level completed: 98%, Points required for next Level: 4
    iDr0id's Avatar
    5531
    Cle, Ohio
    471
    11 times
    Im seeing 1800s and 2200s and higher on ebay. These batterys come with the door as well. My questionS are 1. Are any ebay extended batterys any good, and 2. Will an extended battery fit without problem in my tpu case
    Points: 2,008, Level: 27
    Level completed: 6%, Points required for next Level: 142
    Overall activity: 1.9%
    tt2015's Avatar
    2620
    81
    It's a crap shoot when buying non oem batteries. I know of people that have success. Personally for me I've tried three different non oem batteries and two will not charge with my phone the third will charge but does not last. My stock battery last longer. I know the BH6X is the only oem extended battery. To me it's not much of an upgrade.
    iDr0id's Avatar
    5531
    Cle, Ohio
    471
    11 times
    How about the door? Do you know id they work ok with a tpu case
    X Pursuant Achievements:
    joshw0000's Avatar
    19839
    591
    22 times
    Be careful with non-oem's. I have two that will not charge in the phone and the phone will not display remaining battery percentage. The phone powers off without warning and you'll have to swap batteries to get it to power back on.
    Points: 9,280, Level: 64
    ryant35's Avatar
    7730
    SoCal
    1,706
    57 times
    I've never gotten a decent phone battery from eBay. I bought the extended battery from Verizon and it works great, it's not worth trying to save money because junk will end up costing you more.
    iDr0id's Avatar
    5531
    Cle, Ohio
    471
    11 times
    Im assuming everyone is going to tell me the same thing? My x has beeN getting like 5 hours of heavy use. It sucks ass
    joshw0000's Avatar
    19839
    591
    22 times
    I don't know what that case is, but unless it has a larger back cover, most likely an extended battery wont fit in it. I'm not trying to discourage you from getting a non oem battery, just giving you personal experience feedback. I no longer use my non oems but keep one at work and one at home for battery emergencies. If you're ok with the phone not recognizing the battery, go for it. You can only lose a few bucks if you don't like it.
    A couple things you might want to consider to increase your current battery life:
    If you're rooted, undervolt the phone
    Boot to recovery and wipe battery stats (haven't tried on the X but worked on a old phone)
    Use wifi when available
    Change battery settings in battery manager (if on a blur rom or stock phone)
    Remove un-needed widgets
    Lower scan intervals of widgets and power draining apps
    STOP DOWNLOADING PORN!!! j/k
    iDr0id's Avatar
    5531
    Cle, Ohio
    471
    11 times
    I use autostarts and startup. Cleaner, have all the bloat frozen and have stock rom. How do you undervolt nowadays, I liked it on 2.1 and never did it on my 2.2. And btw the tpu case is the silicone case that is smooth, its like the verizon one but I have the argyle one, its just smooth silocone
    joshw0000's Avatar
    19839
    591
    22 times
    If it's silicone it may stretch to accomodate a larger battery. I use QuickClock to undervolt. It automatically calculates the lowest vsels your phone can operate at. Also, don't use any task killers. They'll only force the phone to keep restarting countless apps. Autostarts is a little different, it should be fine.
    joshw0000's Avatar
    19839
    591
    22 times
    Since your phone is stock (and obviously rooted if you're using autostarts), you might want to look into deodexing it or flashing a custom rom. The stock phone is odexed. Use root explorer or some other file manager to navigate to /system/app. Notice that every app has two files. Deodexing packages them both into one and the phone uses less effort to open and run them.
  1. Extended battery issue or battery killing apps?
    By trogdor in forum Droid X Accessories
    Last Post: 09-30-2010, 12:35 PM
  2. Spare Ebay generic battery
    By hyperx2002 in forum Droid X Accessories
    Last Post: 09-29-2010, 12:19 PM
  3. Extended battery owners..has your battery life gone down?
    Last Post: 09-15-2010, 05:12 PM
  4. Battery App that adjusts for extended battery?
    By B360155 in forum Droid X Apps
    Last Post: 09-04-2010, 02:45 PM
  5. Extended Battery - Verizon has no idea what battery they're selling
    By shinjaejun in forum Droid X General Discussion
    Last Post: 08-19-2010, 10:29 PM
are ebay extended batteries junk
are ebay extended batteries safe
are extended batteries safe
are generic ebay batteries safe for droid x
droid x extended battery ebay
droid x extended battery from ebay
