OBDII Bluetooth adapter
This is a discussion on OBDII Bluetooth adapter within the Droid X Accessories forums, part of the Droid X Extras category; I guess this is an accessory lol I'm looking for one to plug into the port on my 95 F-150 it has a 5.8L EFI ...
Results 1 to 10 of 18
Thread: OBDII Bluetooth adapter
    Points: 20,391, Level: 90
    Level completed: 9%, Points required for next Level: 459
    t.crawford714's Avatar
    17481
    Wisconsin
    2,681
    50 times
    I'm looking for one to plug into the port on my 95 F-150 it has a 5.8L EFI 351 Winser if that matters...
    Watch out, the mods are watching....they're all watching...
    If you feel I helped you be sure to use the "Like" button
    Need additional help? PM me.
    I am NOT responsible for anything that happens to your phone.
    A proud owner of a rooted DX
    Points: 7,762, Level: 59
    Overall activity: 1.2%
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    Quote Originally Posted by t.crawford714 View Post
    A plug from obd 2 to what? LoL
    sent from mopar-x from in side a bomb shelter
    Sent from Mopar-x
    17481
    Wisconsin
    2,681
    50 times
    It would be an adapter to plug into the port of the truck to bluetooth connect to my DX
    17481
    Wisconsin
    2,681
    50 times
    So the Bluetooth piece would be would be the male adapter, the truck has the female. it would communicate with my DX over Bluetooth. I know they have them for the newer vehicles, not too sure about a 95 though
    mopar-x's Avatar
    22071
    Buffalo N.Y.
    1,132
    56 times
    Yor Ford has OBD 1 I haven't seen any thing like that for OBD 1. Vehicles before 96 had ODB 1 and vehicles after 96 are OBD 2 . BUT you maybe are lucky enough to have OBD2 plug on your truck cause its a 95 look under the dash on the passenger side.
    Sent from Mopar-x
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    Obd-ii is a standard. No worries. It will work fine.
    Edit: But you might not have obd-ii, like he said. So nevermind.
    17481
    Wisconsin
    2,681
    50 times
    Quote Originally Posted by mopar-x View Post
    I will look, because I know some 95 models have one and the others have the other...stupid change over years...
    100 Experience Points3 months registered31 days registered7 days registered
    TomRep's Avatar
    27327
    Actually some 95 Ford trucks have both. Been awhile since i worked on that year with that circumstance, but i believe you can only get limited data out of the OBDII connector if its got both.
    Tom
    Points: 2,308, Level: 29
    Level completed: 6%, Points required for next Level: 142
    Overall activity: 0.6%
    Arak-Nafein's Avatar
    7790
    122
    Just throwing this out there.
    I saw this the other day & considered getting it to have something to play with & extend the functionality of my droid X with my car. But I decided to skip it because I'll be getting an SCT3 flash tuner which will perform the same functions.
    PLX Kiwi Bluetooth - Connect your Droid mobile device to your car's OBD2 OBDII Port
    Tho, as others have said, you need to make sure you have ODB2.
    ScooterCat likes this.
    Points: 1,526, Level: 22
    Level completed: 26%, Points required for next Level: 74
    jgraham4598's Avatar
    27237
    Canton, OH
    71
    I actually just got mine two weeks ago. It is pretty sweet. Definitely make sure you have OBDII. I got it off amazon for about 50 bucks. It uses the Torque app in the market. The paid version is just over four bucks and worth it. Just make sure the one you get is compatible with the Torque app or whichever app you decide to use with it.
  1. Car cigarette lighter to multiple USB adapter
    By OfficeLinebacker in forum Droid X Accessories
    Last Post: 02-24-2011, 10:46 PM
  2. Use X as a wireless adapter/usb tether?
    By OchoDirko in forum Droid X General Discussion
    Last Post: 12-30-2010, 02:07 PM
  3. Mini to Micro USB adapter
    By epsilonbass in forum Droid X Accessories
    Last Post: 11-19-2010, 12:41 PM
  4. Mini --> Micro USB Adapter
    By AndroidScott in forum Droid X General Discussion
    Last Post: 09-10-2010, 01:09 PM
  5. Replies: 5
    Last Post: 08-17-2010, 08:35 AM
best obd2 bluetooth adapter
bluetooth odb2
micro usb to obd2
obd bluetooth adapter
obd ii bluetooth adapter
obd2 bluetooth
obd2 to micro usb
odb2 adapter
odb2 bluetooth
odb2 bluetooth adapter
