Fix for hard button presses with an Otterbox Commuter case!
This is a discussion on Fix for hard button presses with an Otterbox Commuter case! within the Droid X Accessories forums, part of the Droid X Extras category; The one thing thatís bothered me about my Commuter for the DroidX has been the ridiculously hard button presses. Today, I cut a small strip ...
Results 1 to 2 of 2
  • 1 Post By vocoder
Thread: Fix for hard button presses with an Otterbox Commuter case!
    vocoder's Avatar
    8523
    12
    Today, I cut a small strip of thin (very thin) cardboard equal in size to the raised buttons on the case and slipped it into the groove inside the case. Instantly better. I used a tiny piece of scotch tape to keep it in place while I put the phone back into the case, but it's fine without, as long as the cardboard is seated into the groove.
    Use thin cardboard Ė otherwise youíll stretch out the silicone and leave a gap in the case at the bottom edge of the screen. Your thumbs will thank you! Good luck.
    mandog202 likes this.
    mandog202's Avatar
    25661
    Huntsville AL
    261
    20 times
    I just tried this using a strip cut off of the box the case came in, MUUUUUUUUCH better! (defender series)
  1. Hard Snap On Case vs Silicone Soft Case
    By omnicious in forum Droid X Accessories
    Last Post: 01-19-2011, 06:40 PM
  2. incipio vx otterbox commuter review
    By hemi1300 in forum Droid X Accessories
    Last Post: 12-05-2010, 03:30 PM
  3. otterbox commuter or incipio, which would u choose and why?
    Last Post: 12-01-2010, 10:20 PM
  4. will the otterbox commuter fit into Seidio holder?
    By droidxdroid in forum Droid X Accessories
    Last Post: 11-26-2010, 06:55 PM
  5. Anyone experiencing lag on hard button presses?
    By jcstarr in forum Droid X General Discussion
    Last Post: 08-08-2010, 11:32 AM
how to make the buttonon your otterbox easier to push
otterbox button hard to push
otterbox buttons hard to press
otterbox buttons hard to push
otterbox commuter power button hard to press
otterbox hard to press buttons
otterbox home button hard to press
otterbox home button stiff
the otter box defender screen press hard
trouble pushing buttons on my otterbox commuter case for samsung s 3
