Otterbox Defender built-screen issues
This is a discussion on Otterbox Defender built-screen issues within the Droid X Accessories forums, part of the Droid X Extras category; Hi All, Does anyone have issues with their Defender case and bubbles between the glass and the built-in screen protector? Does anyone have a solution ...
Thread: Otterbox Defender built-screen issues
    zoomdroid's Avatar
    103
    Hawaii
    51
    Hi All,
    Does anyone have issues with their Defender case and bubbles between the glass and the built-in screen protector? Does anyone have a solution to keep the bubbles out?
    Points: 5,624, Level: 48
    Level completed: 37%, Points required for next Level: 126
    Overall activity: 8.9%
    noXcuse's Avatar
    19040
    Chesapeake, Va.
    1,313
    59 times
    I'm not getting bubbles, but going in and out of the cold gets a thin layer of condensation between the screen and protector. When that happens, the screen gets weird acting, and typing sucks. I'm on the verge of cutting it out and putting a sticky protector on the screen.
    Chicken pecked on my Droid X.
    Points: 2,089, Level: 27
    Level completed: 60%, Points required for next Level: 61
    wilyums's Avatar
    18637
    KY
    243
    Try using a very thin layer of some sort of talcum powder under the screen. It doesn't take much. This will take of the issue of bubbling our rainbow effect. Just sprinke a little powder on the inside of your screen protector and then wipe or blow it out. The residue you leave behind will take care of to to your problem. I hope this helps you.
    Proud owner of a Rooted DROID X
    Briefcase's Avatar
    14287
    6
    I left the sticky protector on and put the Defender cover over it (they kind of stuck to each other). I've no issues at all. I didn't think about it I was just being lazy but it is working nicely.
    Points: 3,897, Level: 39
    Level completed: 65%, Points required for next Level: 53
    500 Experience Points250 Experience Points31 days registered7 days registered100 Experience Points
    Xzombie69X's Avatar
    5584
    179
    This is why i wont buy a case with a built in screen protector, talcum powder or baby powder works.
    Stock Droid X2
  1. Otterbox Defender w/ Extended battery?
    By Cincinnati in forum Droid X Accessories
    Last Post: 12-12-2010, 12:17 PM
  2. screen protectors, which one is better? VZW or otterbox
    By hemi1300 in forum Droid X Accessories
    Last Post: 12-08-2010, 10:50 PM
  3. Can I use the built-in android recovery?
    By ixc in forum Hacking Help
    Last Post: 11-15-2010, 01:48 AM
  4. Earbuds with built in microphone?
    By pricelady in forum Droid X Accessories
    Last Post: 08-18-2010, 12:39 AM
  5. Any way to stop the built-in motorola apps?
    By y10k in forum Droid X Apps
    Last Post: 08-12-2010, 05:15 PM
Otterbox built in screen protector
how to get rid of rainbow effect on otterbox
otterbox defender rainbow
otterbox defender rainbow effect
otterbox defender screen problems
otterbox defender screen rainbow
otterbox rainbow effect
otterbox rainbow screen
otterbox screen protector rainbow
otterbox screen rainbow effect
