Found Case For Extended Battery
This is a discussion on Found Case For Extended Battery within the Droid X Accessories Reviews forums, part of the Droid X Accessories category; What was the case like? I just ordered it Sent from my DROIDX using Droid X Forums...
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Found Case For Extended Battery
    Points: 378, Level: 7
    Level completed: 56%, Points required for next Level: 22
    Overall activity: 0.0%
    CrimsonTide's Avatar
    40320
    Points: 1,911, Level: 26
    Level completed: 11%, Points required for next Level: 89
    Overall activity: 0.6%
    may0799's Avatar
    2874
    Georgia
    139
    I know several people that use the 3500 mah extended battery with the otterbox defender. It does require a little modification. You have to dremel a hole in the hard case to allow the battery to fit through, but when the silicon cover is installed you cant see the hole or the larger battery.
    40320
    I got the case that glshub posted a link to. It's pretty nice. It's a little loose on the sides and the volume buttons are a little hard to get to but all in all for $15 its a good deal. It's a rubber case but has a nice feel to it.
    Points: 1,810, Level: 25
    Level completed: 10%, Points required for next Level: 90
    Overall activity: 8.6%
    glshub's Avatar
    39743
    252
    I have had my case about a month now. I honestly thought, the way it fit, it would become loose after a while. It hasn't. I have to take ut off every time I do a battery pull, which is the only way to completely charge the 3500 battery. It still fits tight and is holding up well.
    I would like to have a thicker case that provides more damage control for people like me that have fumble fingers.
    I would go with the otterbox if it would fit my battery. Maybe someday there will be a case that meets my needs. The 3500s are here to stay and surely someone will make one.
    Sent from my Milestone X using Droid X Forums
  1. Extended Battery + Case?
    Last Post: 04-08-2011, 08:34 PM
  2. Droid x case that fits extended battery
    By veggiop in forum Droid X Accessories
    Last Post: 03-27-2011, 11:02 AM
  3. Which case(s) would fit my Droid X w/ extended battery?
    By Crazy in forum Droid X General Discussion
    Last Post: 11-10-2010, 03:19 PM
  4. i need a case that fits extended battery cover!
    By tomah in forum Droid X Accessories
    Last Post: 09-18-2010, 12:04 AM
  5. Platinum Case w/Extended Battery w/Pics
    By B360155 in forum Droid X Accessories
    Last Post: 09-03-2010, 06:40 PM
case for droid x with 3500 battery
cases for droid x with extended battery
clip on case for droid x extended battery
droid x 3500 battery and case with clip
droid x case extended battery belt clip
droid x case with thick extended battery
droid x clip with gorilla battery
droid x extended batterbelt clipy
droid x extended battery belt clip
droid x extended battery belt clip case
droid x extended battery clip
droid x protective case with extended battery
gorilla gear droid x extended battery review
gorilla gear for a droid x
how thick is motorola droid x with extended battery
motorola droid x cases for 3500mah battery
protective case for droid x w/extended battery
skin for extended battety phone
usa gear droid x cases
what case will fit my droid x with 3500 battery?
